I have a variable speed powermatic drill press and as I rotate the wheel to change speeds I feel like can feel each tooth interact with eathother and it isnt as smooth as it should be. I called Powermatic customer care and he said that I can apply some bearing or white lithium grease to the rails and gears to help it glide better.
My question is which brand/model/type should I choose that works best for this situation?
Right now im choosing between Valvoline SynPower Synthetic Automotive Grease, Lucas Oil 10533 White Lithium Grease and a few other. However, ive seen people mention Moly grease and others as quality stuff, but wonder if that is the same as the aforementioned greases. I don't mind spending whatever (under $50 lol) to get the best or even just better.
The manual only states "It is good maintenance practice to periodically clean the pulleys with a non-penetrating lubricant, such as WD-40, wipe off any excess, then apply a light oil to the pulley shafts. NOTE: Do not use graphite- or silicone-based lubricants. - Link below for help if needed
That's for the pulleys, but doesn't say anything about the gears or rails or whatever. So this is all Chinese to me and I'm asking for guidance. Thanks for pointing me in the right direction.
http://go.rockler.com/tech/Powermatic-1-HP-Drill-Press-PM2800B-Manual.pdf
