I don't know how sealed a crank case is, but if the oil is hot, I've seen increased flow rates by removing the cap. Pretty sure the PCV on most crank cases is there to release positive pressure from blow by and often has a ball inside to seal against vacuum. It might make a few seconds difference to the total drain time, but not a lot.
