I usually just crawl under there and change the filter first, than drain pan. While pan is draining grease all fittings. Replace filter and drain plug. Go inside and wash hands, come back and fill. Check oil, close hood, go inside and take shower.
Originally posted by thooks:
Whew....
This place is getting tight.
"outage" time?
5.2 quarts. Five point TWO quarts?
No, you need to at least get it on ramps to access the filter. It's on the backside of the engine block just under the intake manifold.quote:
Originally posted by Largelarry:
Can I reach my daughter's new/used 03 Civic without a jack or ramps ? I been wondering cause I'm going to do it soon.
