Either way will get the oil change done just fine; however, I am always coming up with these frivolous curious questions. So then in the spirit of curiosity. . . .
What say you?
quote:Did I say anything about how long to drain it? If you begin one event before another, but end them both at the same time, which event lasts longer? I think you need to learn both to formulate your questions better and to understand what someone is saying in their reply.
Originally posted by GoldenRod: Tosh: We already did a thread about how long to let it drain. I wanted to know if you pull the drain plug first and let it drain, or replace the filter first, and THEN pull the drain plug.![]()
quote:That brings up an interesting maneuver that I might try.
Originally posted by Largelarry: After the pan drips awhile I pour a half quart or so of cheap dino thru it with hopes of flushing out some pan crap. Can't hurt, right? And it makes me feel better.
quote:It depends on where the return oil galleries drain into the pan (or even how the car is tilted at that moment). If upstream opposite from the drain plug, there might be some rinsing action. You could catch this rinse oil in a clean container, and decide for yourself if it's worth it for your case. To me it seems as if there's actual crud on the bottom of the pan, it would be best dislodged during the main first drain, when the flow is fastest. And if there is some glob of dirty oil hanging by surface tension onto the drain hole lip, a little clean oil upstream would force it out. Is it worth it?
Originally posted by OriginHacker21: Do any of you guys think there is an advantage to pouring half a quart in after draining to kind of "flush" things out?
