I want to do a drain and fill on our camry, looking for input from anyone who has dealt with a similar application. Every once in a while when the car is cold and i pull out of the drive way and go forward the transmission hesitates to change gear, unless i pull my foot off the gas, im not sure if thats fluid related but i want to service it anyway, im not buying this lifetime bogus.
I've seen a couple of youtube videos where they drain and put in the same amount through the side plug located behind the drivers side tire. Ive also heard the you have to check the temperature of the fluid afterwards, is that necessary or just put in the same amount you take out ?
I also purchased the mighty vac 7201, very solid built unit, already used it on the mustang for tranny service and worked great, plan to use it to dispense fluid in the camry, thanks guys.
