Ok, I know it's anecdotal evidence but...quote:
Originally posted by Patman:
An engine may not completely fail due to the oil, but I guarantee you that choosing the wrong viscosity, or a brand that doesn't protect as well, will shorten it's life. I know a lot of mechanics on here might not trust UOAs, but to me, if I used one oil and consistently saw wear numbers of 3ppm/1000 miles (for iron, lead, aluminum) then it would not last as long as if I used an oil that consistently showed wear numbers of 2ppm/1000 miles.quote:
Originally posted by buster:
It just proves that an engine will rarely fail do to oil. Whether you use Mobil 1, Redline or Amsoil, it isn't going to make your engine last longer. As you experienced, QS 30wt did just fine.quote:
I've been drag racing for over 25 years 1/2 of that with a all out race car(10 sec Dodge Demon with 440 Mopar power)and all I've bben using is Quaker State oil,was using 30wt,but this new engine gets 10w40.My engines usually last 6 years,and I've never lost one,just go thru them when the compression starts to go
In his case, the compression on his engines would start to go after 6 years. A better choice in oil would've meant he could've gone longer between rebuilds. You often hear testimonials from all different types of amateur racers (not just drag racers) who used to rebuild their engines twice or three times a season, but then switched to Redline or Amsoil, and their rebuild rate went way down.
1. A friend used to run mud racers and also monster trucks back when they still used 9" Ford diffs. Using generic gear lube they would need to rebuild these rears at least once a month during the racing season.
Changing to a synthetic gear lube allowed them to run all year with no rebuilds.
2. In the early 80's I remember a man named Yoshima who became semi-famous in M/C racing circles for things he was doing with Honda 400 engines. These were plain bearing engines and one of the problems he was having with them was crank breakage.
Changing from dino to a synthetic oil stopped this problem completely.
3. I worked on a number of Yamaha road racers back in the day and no matter what, they would consistently stick pistons and require early crank service unless good quality ( synthetic ) oil was used as premix.
There's no downside to using good lubricants other than the perceived higher cost. I say "perceived", because I think long term the cost may well be lower. Broken or prematurely worn parts parts cost money too...
