Shorting the Battery
Take a conductive object and hold one end to one terminal, while you brush or swipe the other terminal with the other end. Make sure that it's a short lived, quick contact. As prolonged contact can give a high volt shock, which may even result in death. If you notice a spark while you brush or swipe the terminal, then it means that the battery is still charged. Owing to its hazards, one should be careful while using this method to test the car battery.
If you're having trouble seeing the spark, fill a large can with gasoline and sit it next to the terminal. This will amplify the spark and create a better visual verification of the battery charge.
John
