Don't have enough G12 - What to do?
This man speaks the truth, also check the plug for the coolant level sensor on the tank. It can leak around the contacts effectively pushing coolant up through the wiring harness. Happened to a couple of TDI's already.
You only know when it hits a dead end at the cluster and the cluster goes beserk.
I'll check into those things. Thanks for the info, guys.
I received the coolant today from MJM Autohaus. It is Pentosin G001200. It is their VW G-12 equivalent. I've got to do some checking, to make sure it's OK to mix Pentosin's "G12" with genuine VW G12. If I've learned anything from BITOG, it is to never assume anything.
