Having primarily driven older Honda vehicles through the years, with my newest being a 2008, I ran across an interesting behavior of the ABS pump on my 2020 Ranger and was curious if anyone else had noticed that their cars are programmed the same way.
The situation was, Ranger was sitting at the top of my sloped driveway and I wanted to simply roll it down the hill to park it next to the door for the night. Moving a car 20 feet down hill doesn't require starting the vehicle, so I turned the key on, put it in neutral and rolled it down. Needing to stop at the end of the trip I wailed on the brake pedal as I expected no vacuum assist (since the truck wasn't running). What I got was an initial hard pedal (expected) followed by full-on activation and wheel skidding of the ABS pump.
I've never heard of someone programming a system to work like that, although it does make sense. If you're in a panic situation and the engine has failed, the car will take over and perform maximum stop to hopefully prevent you from hitting something solid.
Just found it interesting as I've never experienced that, and I suspect 99.9% of the public never rolls their car with the engine off, so they probably won't either.
