for a standard 3k 3month oil change interval, wouldnt it make most sence to run a 0wxx no matter what climate you are in?
the only reason i can think of to use a higher cold number is for an engine which develops sludge quickly. as a 10w30 will not sludge as easily as a 0w30 for example, because the 0w30 has more VII's than the 10w30.
am i correct in assuming these 2 things?
