This is a picture of the brush area for bow thruster motor in a boat. The bottom screw holds the wire to the brush and below it a silver colored bracket to an overheat thermistor. The upper screw holds another wire to the brush and an electrical connector to the thermistor.
So for the lower screw I would think the motor brush wire would need the best electrical connection and would be first. Then the bracket for the overheat thermistor. But I could understand if someone said to do the best temp sensing in this area the bracket for the overheat thermistor comes first.
The upper screw I can see no reason why the electrical connector to the thermistor is first.
I think the picture is wrong.
It's many hours to get the motor off the flange and take it apart.
I assembled it thinking the brush wires need the best electrical connection and should go first. Then came across this picture. It's half assembled now. Easier now to take it apart and swap the order then to put it all back together and figure out I got it wrong.
