Does Quaker State Ultimate Durability use GTL base stocks?
New England
Anyone know the answer to this question? I figure with the huge Pearl plant SOPUS has going maybe they are using GTL in Quaker State Ultimate Durability?
Thanks
You will be hard pressed to find the true answer, but i think yes they are since when we talked to them they have a surplus.
If you call 1-800-BEST-OIL which is 1-800-237-8645 you can be connected directly to the technical call center which has very knowledgeable people there, and if they need help the scientists are right down the hall.
Prolly is ...
Thanks
They probably are. They have enough of it cheaply enough.
There are some VOAs that suggest that they've used it in some batches of Quaker State Conventional and Pennzoil Conventional.
Incidentally, GTL is a Grp III basestock.
