I was wondering what causes oil to darken as it is used. Is it, dirt in suspension, a sign of the additives being consumed, or just a normal change as the oil is exposed to the combustion environment? I have a 350,000 camry and change the oil consistently at 3,000. The oil starts to darken fairly quickly and comes out at the OCI almost looking black. At first I thought this was just because of an oil engine and the oil getting dirty but why should the oil be getting any more dirt in it just because the engine is old? There are no holes in the air intake system and the air filter is clean and a good brand. Then I started thinking why would the darkening of the oil have to be from suspended dirt and contaminants.
So, does oil darken with use from suspended contaminants or is it just a normal chemical reaction when exposed to the stress of the combustion process?
Also, does the darkening relate directly to the need for it to be changed or is its color irrelevant as an indication of the life left in the oil?
