Everything from the pump-down will come out the bottom hose, but there's still quite a bit left in the heads and heater core that has to be pushed out using the engine's water pump. If you're looking for a complete flush, simply remove the top radiator hose and point it in a safe direction...then take the cap off the radiator and fill it with fresh water and keep the garden hose handy.
Turn on the engine and wait for the thermostat to open..at which time hot coolant starts flowing out the top hose. Use the garden hose to keep the radiator full while the engine is running, until the water coming out the top hose runs clear. Next, start pouring in the new 50/50 mix until you see it start coming out the top hose. Have someone shut off the engine. Top off the radiator, reattach the top hose, and put the cap on. Fill the reservior with 50/50 and start the engine again, keeping your eye on the reservior. Keep it filled until the engine stops taking from it.
This is a method used to prevent air bubbles from getting trapped in the heads. Older GM 3.1 V6s and some Dodge V8s have valves in the intake manifold to help bleed air from the top of the engine...other engines don't have these, so any air you pumped in remains there, possibly causing hot spots in the heads which can warp them, leading to head gasket failures, etc.
Hope this helps.
