I am not disagreeing with the fact, that both gauges are a big help but, do they really tell you what is happening to the bearings, rings and cylinders?
Agreed...the gauges are measuring sump temperature and the pressure in the main oil gallery in the engine.
As I've stated previously, from that main gallery, oil passes through :
* Main bearings (turning at crank speed)
* Cam bearings (turning at half speed), and speed is one of the key design parameters in the lubrication regime of bearings.
* Oil squirters (generally multiple), which depending on their design, may be measuring kinematic viscosity (long pipes), or density (orifices)
* Rod Bearings...
(Go back to the bearing tutorials earlier in the thread, and see the difference in rotational speed has on lubrication.)
All of these items are in parallel (bar the rod bearings), so Caterham's OP gauge is measuring the resistance to flow across all of them, as an average. So asserting that each of these points is lubricated adequately by having pressure is false, it's a real good guess, I guess.
The sump temperature is the average of the temperature rises across each of these areas.
Bearings have measured and calculated temperature rises of 10s of degrees Celsius. Caterham has refuted that as "not feeling right" in the past, but it's fact.
It doesn't "feel" right to a person watching a temperature gauge, as the sump temp is the average of bearing temperature rises (tens of degrees), piston squirter temperature rises (not much to some depending on design), and chain squirters (not much rise),and oil pump bypass temperature rise (should not happen, as I agree it's wasted power, and unnecessary heat). Sump temp doesn't tell you exactly what is going on in any of the bearings, but I agree, you can gain a "feeling" that things are generally good, or turning to whoop...It's not a scientific, empiracle proof that all is good.
Now getting back to the rod bearings.
They are fed oil from oil that's already been through the crank bearings, have picked up heat (aforementioned tens of degrees C), lost pressure, lost viscosity, and reallyhave no direct connection to the main gallery pressure gauge, nor have the operating temperature monitored as the rise is diluted by all of the other feeds back into the sump. Rod bearings are operated in a highly cyclic load pattern, which is difficult to design for anyway.
Main bearing viscometer may or may not reflect adequacy of lubrication in the rod bearings.
, I think that the hot, atomised oil being flung out of rod bearings, being first contact with piston blowby gasses is probably the most likely place for varnish to be created in an engine. Hypothesis that I'm working on at present.
