195/60R15 General Altimax HP tires weigh 16.5 lbs each. The very popular Goodyear TripleTreds in the same size weighs a good 23.5 lbs.
That's difference of 7! lbs. of the WORST and MOST unsprung of unsprung weights since the tire is farthest from the rotational axle = worst than weight of the wheel.
A car with Altimax HP tires would have a good 28 fewer lbs. of this bad stuff.
The great thing about lighter tires is that they don't compromise performance, traction, or cheapness.
Certainly weight should not be the ONLY factor but should be ONE of the factor and manufacturers should strive to reduce weight whenever possible.
