Do you follow severe differential oil change interval?
You guys with drain plugs make me jealous 😂
Only my Jeep - but I find the GM gaskets good enough to back off bolts until they leak - then go gather oil - once nearly drained - give it a couple ounces of new oil to flush the bottom - torque and fill …
(clean the magnet on fill plug removed at the start) …
My 2017 Nissan Titan says “inspect” the differential, but change every 20k miles if towing a trailer or driving in dusty areas. Out of curiosity I checked the manual for my dad’s 98 Chevy and it said for a locking diff change it at the first oil change and then every 15k miles. I’m 99% certain that wasn’t done.
Is any Chevy driver actually changing their differential oil every 15k miles? I guess it’s time for me to start. Of course the rear locker on this truck doesn’t have a drain so I guess I’ll be sucking it out or buying a new gasket.
There is a big difference between how most passenger vehicles are used and something that really sees severe service. For a typical SUV or pickup that hauls the kids around and goes to the home center on weekends most people will never have an issue even if the differential fluid is never changed. For vehicles that are usually at max GVW and/or towing heavy, the differential service is more important. Even if the oil is only changed once that is much better than never at all.
My '97 C2500 Suburban has done a lot of towing in its life. For 20 years it towed a camper across the US 2x per year, while loaded with 4 adults and full of luggage. I have all of the service records. It did NOT have that early differential service at the first oil change, instead it needed new axles and wheel bearings when it barely had 20K miles on it. It has also had the axle seals replaced a few times since then, along with a pinion seal. Last year I popped the cover off to change the oil and inspect the gears/bearings and I was surprised at the amount of metallic goop in the bottom of the case. There is large magnet right under the ring gear, and mine looked like a rock with hair growing on it. From what I can see in the service records it only had the oil changed when the axle was repaired. I can't help but wonder if a more frequent service and a better gear lube would have prevented some of the issues.
I can also think of some farm trucks that needed work done on the rear axle. They all hauled/towed heavy and had factory fluid in the axle for the first repair.
My Canyon has to be on a lift for me to get to the fill plug. GM offered a couple different pumpkins on these & I got one that is a complete PITA with the fill plug too high & tucked up out of the way to get to until on a lift. I know I should be thinking if it's already on a lift just take the time to pull the rear cover & clean it correctly but I'd really like to be lazy on occasion with a drain plug lol. If I'm breaking the seal on the rear cover, I don't want to take the chance on the darn thing leaking when zipping it back together. If the fill plug was in a better place I'd try to use my vacuum pump to suck it out warm & just refill. Grrr. :ROFLMAO:
The number of QT in the differential is only a few, changed not very often so the extra cost is negligible.
My feeling is if you go to the hassle of getting Amsoil products why not get the best ones.
I buy their SVG gear oil and their best ATF.
I see.
I hadn’t been under the rear end of the Chevy in a year or so. Somehow I don’t think differential lubricant is the likely failure point of this vehicle.
Most differentials never get their oil changed and go to the junkyard on their factory fill :sneaky:
This is reality. They aren’t a complex item. Though some can get whiny I suspect due to insufficient maintenance.
Diff fluid on its own will likely last forever, but the fluid will get fully of micro metal particles that can only be removed if drained. IMHO.
That’s just it. It’s not motor oil, no exposure to fuel or combustion byproducts, or severely oxidizing conditions. It can oxidize, can gain moisture, can disperse metal particulates, etc.
Old high mileage doffs will get a nice coating of gunk on the outsides. This likely also affects heat transfer. Here’s a Dodge Ram Dana 70 with 445k.
If rear diffs didn´t need to be changed, then they would all be advertising lifetime oil in rear diffs.
They aren’t advertising them this way but I bet you there are a lot of very high mileage cars out there that have never had a rear end fluid change. It just doesn’t see the same level as stress as a transmission or engine and doesn’t get the contamination.
I never changed the rear end fluid in my 98 Corvette and I had 215,000 km on it when I sold it.
I wasn’t planning on doing the rear end fluid in my current Corvette for a while but I had some warranty work done on it at 71,000 km and they changed the rear end fluid during that work. I likely won’t change it again until maybe 200 to 250,000 km.
This thread reminded me thinking about gear oil so I did a suction change on the front axle of our Expedition. Pulling the cover is a big job on that rig as you have to disconnect a bunch of suspension components and shift the axle back to make room.
It was at least 60k since the last time it was done, but the stuff I pumped out was not much darker than the stuff I pumped in which makes sense as 4WD is rarely needed around here.
I'd guess the lack of gear oil will be the COD of that rear. The rear pumpkin cover is probably rusted paper thin with pinholes.
I think those spring mounts will probably snap off first. This truck gets driven mostly off-road now.
View attachment 219931View attachment 219932
I agree the lubrication of the differential is much less demanding than motor oil on an engine but I have seen the gear oil come out pretty black looking from the rear differential case.
Absolutely. And murky from the front one if it doesn’t get hot enough often enough.
A little off topic, reminds me of my dad's 05 blazer. Last year for Canadian model. It sat in the garage for 7 years. (2011) Then I needed to borrow it since insurance wrote off my wife's 2013 RAV4(in 2018) Only had 1 vehicle at that time. The pumpkin diff looked so rusted I was afraid to remove the bolts for fear of snapping bolts. IIRC the diff fluid hasn't been changed at all. It sits at 168k kms. Love that blazer, always started. Still in his garage unwilling to sell it. If I recall there's no drain, you had to remove the cover
