There are plenty of oils out there that are fine for your bike. Look at HDs additive package. It is going to be about 1000 Phos, and 1100 Zinc with detergents including Calcium, Boron, and Magnesium for both the dino and syn 3. I don't know of any SG oils out there that meet that but enough non SGs that do. For dinos I would start with Valvoline four stroke MC oil and VR-1 street legal, Bardahl, M1 15-50 PCMO, Brad Penn, and probably more. These are all in the $3.50 to $5.00 range. The HDEOs are good too but I've not decided that a 40 weight is ok uless up north or for a winter fill. Unfortuanately the problem with HD oils is that the price is not competitive. Same for syn oils. When you go up a class look at Red Line, M1 Vtwin, Amsoil, Motul and others. All these oils will meet or beat HD's offerings. all the HDs will run fine beyond warrenty with these. Question is if you buy them for life like I do want to use. Well I've settled on Red Line for the new bikes and the 94 is running M1 15-50 for now but trying Brad Penn Vtwin 20W50 next year (case in the basement).
HD oils are fine but way over priced and easily beat. Not a fan of SM oils as it appears that to work for API you have to wear EPA knee pads. Unless you live in Cali there is no Cat Converter on you bike so why degrade your oil to appease the EPA?
