Do I have to replace the throttle body gasket when cleaning it?
xsr
Hey guys,
I’m planning to clean my T.B and gotta ask if I should replace the gasket. I bought an Ajusa one, is it ok to use it or better to reuse the old OEM one?
I mean, even if the old gasket looks ok, should I swap it with the Ajusa one just to be on the safe side?
My car is 2016 Mazda 3 2.0L with 76K miles.
Thanks!
Hey guys,
Thanks!
I'd replace it. You never know how worn the original is even if it looks good.
You may not have to remove the throttle body to clean it, that said you can probably reuse it however if you have a new one it’s obviously preferred and the right thing to do
Have the gasket on hand, but if the old one comes off in one piece I'd reuse it. Otherwise you're scraping it off, gouging metal, and having little bits stick around.
If it's a flat paper style gasket, change it. If it's a rubber o-ring style that is in its little groove, it's probably fine.
Edit: someone above already said the same thing. Lol!
Thanks everyone for the advice!
I just cleaned the throttle body. Actually, the front side looks pretty clean. The rear side had some buildup. The cleaning doesn’t make a noticeable difference in driving, but it seems like good preventive maintenance. Attached some pics.
