Thing has been beeping the last 5 days driving me crazy. Just figured out it was this and not a smoke detector. Do I have to pay for a new one or will Verizon cover it?
I've had to change two batteries. Every time the low battery alarm beeps it freaks my dog out. What did Verizon charge for the direct power upgrade?I've had the same issue about a month ago. The guy that showed up from Verizon said, they do not use batteries or that equipment anymore. He disconnected and removed the battery and charger, and installed a straight up power supply with no standby battery. He said that's all they will do . If you really want to keep that setup, you can buy a replacement battery and install it yourself. They cost around $25 by me in New Jersey, at a electronics store.,,,
You can just unplug the black and red pigtail connectors and leave the battery in place to get the beeping to stop. In a power outage, you should be able to use the landline if you hook up the 12v jump pack to the correct terminals. The battery in the jump pack should be very similar to the FiOS battery. Shortly after a Nor'easter storm knocked out power for several days in 2012, I removed a Group 24 battery from my truck and used it to power the phone line and FiOS ONT terminal for days.I do have 2 landline numbers but rarely does the power go out for more than a few minutes and I could use a cell if needed. If necessary could I just remove the battery? Can I use my jump box during a power outage if I wanted to make or receive calls?
