I am going to attempt to change my coolant from the regular green to G-05. I am going to do the "drain and fill with distilled water until it runs clear"
I have a question. Do I just have to drain the "radiator" and keep adding the water than bring the car up to operating temp and let the thermostat open up and then let it cool and repeat?
Do I need to try to pull the coolant sensor on the block to drain the block too? Also will the overflow tank coolant need to be sucked out with a suction gun or should that be drawn into the radiator?
