- Joined
- Mar 3, 2010
- Messages
- 2,451
I usually open filters, but this is one of the few I couldn't find any good pictures or dissections of so I thought I would share.
The filter in question is a Hastings Premium that I got on sale for $1, I wanted to dissect it to calm my curiosity... and it appeared the filters had sat there for at least 3 years untouched so I was skeptical due to age/price.
The filter was very well constructed and I was quiet impressed, they had about 2 cases of these filters there and needless to say ill be picking up a case of 12.
The filter is of impressive construction, the bypass valve is a spring on the bottom as well. The media is very securely adhered to the metal base plates with glue in a precise non sloppy way. The ends of the media are clamped and glued between metal as well. The media was 70 inches long, 1 3/4 inch high, and had 56 pleats around a interestingly perforated metal center. The media seemed thick but not like the cardboard of a Super-tech I opened, it has a similar look and feel to the media inside the Purolator classic I opened. It also says replaces Puro PL14459, Napa 1334, Wix 51334, and Fram PH6811 above the scan bar of the box.
I have yet to find anything on the filtration rates anywhere after an hr of google... anyone have the info?
I can't ever seem to get any images to [censored] show up here (part of the reason I don't share more of these activities as well).
http://postimg.org/image/oc89kdu4v/
http://postimg.org/image/9lzjyelfd/
http://postimg.org/image/9zmgmvglt/
(Yes I mutilated the filter can a bit to open it, hence the scratches)
http://postimg.org/image/tzr3jtppt/
