I suspect you've got a network configuration issue. -72db is not a great signal but it should be good enough to connect. The signal to noise ratio in your screenshot is 35db which is poor, but again you should be at least able to connect.
Is there a setting for transmit strength in your settings? With clear line of site, this type of repeater should be able to connect over a mile.
Also, are you trying to connect over ethernet on the client side? I would make sure that works before trying to get WiFi working to eliminate as many variables as possible.
