Some snow tires have directional threads like the Michelin Arctic-Alpin.
I believe directional tires are directional by the way the thread channels the snow/dirt at the contact between the thread and the road.
The threads of directional tires are V shape with the wider part of the V at the front part on the road/tire contact. Extreme examples of directional tires are tires on tractors and monster trucks. When a tire slips, the snow/dirt is channeled up the V and out both the left and right sides of the tire while still at the contact with the road. This gives the thread more bite and better traction. Snow/dirt is also expelled from the thread when the thread is no longer in contact with the road as non-directional tires do.
Now, with breaking, the force between the tire/road is opposite, while the rotation of the tire is the same. The force between the tire/road will now channel the snow/dirt down the V thread and into the center of the tire. The snow/dirt can only be expelled when the thread is no longer in contact with the road as non-directional tires do. The thread will not have the additional bite. Channeling the snow/dirt to the center of the tire "may" make it harder to be expelled when the thread is no longer in contact with the road. Causing additional traction lost.
Questions:
1. Is the above theory correct?
2. If my theory were correct, would it be better to reverse the mounting of back tires of a front wheel drive car? The would give more traction to the back to help keep the car stable while breaking.
Questions:
