So every time I first check the oil level in my wife’s Mercedes, when I pull the dip stick it shows zero oil. Absolutely dry dip stick like it is a few quarts low. I reinsert it and count to ten and pull it and it now shows oil, actually sometimes too much oil but it is serviced at the MB dealer and I assume they put in the right stuff and amount. The top of the dip stick where you grab it has a nice “O” ring on the part that goes in the tube. Tight seal at the top.
I’m trying to figure out what causes what I observe and have come to the conclusion that the tube the dip stick rides in goes well into the oil pan and when the car is operating, the oil level is below the tube end. The dip stick does not stick out past the end of the tube. When you shut off the engine, the oil returns to the pan but it can’t come up the dip stick tube because of the tight seal and the other end. Removing the dip stick allows the oil to flow up the tube so a second attempt works. Does this sound right?
Any other cars out there with this peculiar oil level check feature?
