quote:
Originally posted by 96Outback:
Dosage?
Well the Pennzoil 5W20 I've been using in my F150 has 186 and the Chevron has 251.
Do any of the 10w30's approach that, or do they need to I guess is more the question?
ANy oil properly formulated and blended with moly
IMO in the high 100's like 180-200-250 Is minimum to most perfect level needed to have most benefit from moly. IMO, anything here in this range, once engine is plated, will always give the best performance and MPG as long as it's there and as long as the oil has not any HIGH wear metals or SI etc... you get the best IMO of allllll worlds
I love Moly and the moly-like additives, but it is not EVERYthing, other things are in the equation... but in my experience I like the savings on gas, and what seems like a cleaner engine, and the 12-13 times or so I ran out of oil because of a leak, before the meteal to metal screech (happened about 4-5-6 times) you feel a super BOOST in power and quietness, and this is my so called WARNING if I ever run out of oil again because of a blown seal or whatever. Anyhow I do like moly.
