MolaKule
Staff member
That is cool!!This is a four bedroom three bath home with a two car garage and then a RV garage attached that is 18 feet wide 20 feet high 45 feet deep with the option to extend it to 60 feet. It also comes with a 2 ton air conditioning system,50 amp electrical service and water and drainage for your RV. The garage door is 18 feet high.
I have seen electrically heated walkways to eliminate shoveling. Separate electrical panel with a bunch of double pole 20 amp breakers. It just heats the ground to like 34 degrees or something like that so the snow/ice melts.Thanks Molakule for the laugh.
Some years ago when I lived in Michigan's Upper Peninsula I saw a single-wide garage built about 90 feet long from house to road in order to eliminate snow shoveling. I was quite comical.
in the township i live in, you'd need to apply for a variance to do that.I always wanted to start with the garage & a single wide (in the country) & build a modular home (with poured, finished basement) on the property. Mrs. Bullwinkle keeps shooting that idea down...
The house we rented for a few years in Dottenheim had a detached 4 car garage!You guys are allways a little bit envy about our Autobahn, but i am allways a little bit envy about your big garages in the US. Ours here are just dog house sized. Enjoy your garages, guys!
I was kind of impressed when this was built near my place for the sheer efficiency, but they could have had a walkout basement. The back is all windows though. Needs a double wide garage door and a bit higher ceiling for a lift.I pitched the idea of a custom home where the entire main floor/basement was garage, like 3000 sq ft. Elevator to the top floor residence. Wife veto'd.
