Originally Posted By: mk378
That particular type of connector is not too hard to deal with by using slip-joint pliers to hold the whole harness side and squeeze the "button" part of the tab, which is intended to be pushed with fingers but will get hard to push as the plastic gets old. Or push in the slot with a screwdriver as others said.
There is no need to cut anything, don't be literally a hack mechanic and tear stuff up.
Well, I sort-off see that, and I did initially feel a bit bad about doing it.
BUT, "Zen and the Art Of" aesthetics aside, why not?
From a practical perspective the locking function is a PITA, had already cost me about an hour of footling about getting bitten by mosquitos, is probably unnecessary, and if its needed I can substitute a lashing or a cable tie.
Whats the problem with eliminating it?
