A buddy told me he'd been told that an average car tire/wheel filled with nitrogen weighed "several pounds" less than one filled with plain old air. I thought a while, did some swagging, and said lighter, but I didn't even think several ounces. Capri, where are you? Are my assumptions in the ballpark? I'll do a mixture of imperial and metric units and convert approximately convert as I feel like it. I'm thinking of a "normal" tire, perhaps in the range of 255-55/17, but kinda feel the best, standard rating correlation with volume might be with LoadRating, so maybe in the 90-100 range?
I "assume" ...
a torus 7" diameter (~2 gallon/ft)
average circumference ~4.5 ft
volume thus ~9 gallons ... let's assume 44.8 liters for later
1 mole is 22.4 liters at STP
1 mole of N2 weighs 28 grams
1 mole of "air" weighs 29 grams
I don't see that absolute units are important ... to go from 1 bar absolute to 3 bars absolute (about 30 psig) requires 2 volumes added to "empty" tire, or ~4 moles.
External buoyancy won't change, so ignore it.
SO, wild wild wild SWAG ... N2 filled auto tire weighs perhaps between 0.1 and 0.4 ounces less than 1 filled with air. I might say it'd average 1/4 ounce lighter across sizes and inflation pressures ...
Experts, imperts, geniuses, idiots, in between ... chime in. All I'm sure of is that I have too much time on my hands.
I "assume" ...
