Difference between di-ester and polyol-ester
Cordelia, CA
What's the difference. I'm assuming that there is one since diester oils(Amsoil Compressor oil) are comparable in price to PAOs. I've never seen the price of a polyol-ester based oil, but I understand that it is much more expensive.
organic compound that contains two ester groups Di- meaning 2 in greek terms. Polyol containing usually severalalcoholic hydroxyl groups Basically is sounds like the chemicals you would find in any of your synthetic lube. for high thermal stability
