Originally Posted by FordCapriDriver
Originally Posted by LeoStrop
Originally Posted by buster
Diesel oils turn low rpms and have higher levels of soot where as gas engines run higher rpms and have to deal more with acidic contamination from combustion by-products. More defoamants, AO's and acid neutralizing additives are needed. The friction modification is also sometimes different.
Diesel oil can also foam up pretty bad I. High rpms applications I believe. ??
Diesel engines with high load and low rpm may need an oil with a higher HT/HS and high PV coefficient where a aeration isn't much of a concern.
This was one of my doubts on running HDEO on my car. But since it's still stock and i hardly reach 5600 RPM, i decided to use it anyway. Maybe after i start doing some mods, should rethink my oil choice? But since people are having good results running HDEO on bikes and subarus, that should not be a problem.
I am also curious on the difference each oil has, to be able to deal with different fuels. Given that i use a diesel oil on my ethanol car....
Real world experience has shown HDEO does just fine in high revving engines, motorcycles for example.
I agree, HDEO has been and currently is used in outboard motor 4 strokes for MANY years at 4-6 thousand rpm all day. Also used in air cooled generators that sit at 3600 rpm day and night. I have and currently use it in both applications, along with a lot of others around here.
