- Messages
- 21
Am I able to run say Amsoil Diesel 5w-40 oil in the Wrangler 3.0 EcoDiesel instead of the Euro based diesel oil. I’m not an expert so please explain in laymen terms.
API SN engine oil category is required.QuoteEngine Oil Change Engine Oil — Diesel Engine Refer to "Scheduled Servicing" in this chapter for the proper maintenance intervals. Diesel Engine Oil Selection For best performance and maximum protection under all types of operating conditions, the manufacturer recommends engine oils that meet the requirements of FCA Material Stan- dard MS-12991, and that are API SN certified and meet the requirements of FCA LLC. Engine Oil Viscosity (SAE Grade) — 3.0L Diesel Engine CAUTION! *Your vehicle is equipped with an advanced technology Diesel Engine and an emission device designed to limit Diesel Particulate Emissions from being released into the atmosphere. The durability of your engine and life expectancy of this diesel particulate filter emission device is highly dependent on the use of the correct engine oil.* We recommend you use 5W-40 synthetic engine oil such as Mopar or Pennzoil Platinum Euro that meets FCA Material Standard MS-12991 and the API SN engine oil category is required
The thing I don’t understand is I did a search on Amsoil for a 2020 Jeep Cherokee with the same engine I have in my Jeep Wrangler and and Amsoil says to use the Signature Series 5w-40 Diesel oil and when I look I’m my Jeep Amsoil doesn’t have an oil recommendation. It’s the same engine.API SN engine oil category is required.
Yeah, which is ridiculous!API SN engine oil category is required.
That Mobil1 5W40 TDT has as much Zinc as 15W50 for track.I'd use a CK-4 rated Diesel Oil in either a 5w40 or 15w40 depending on whether or not you need a lower cold starting viscosity.
So YES, you can use the Amsoil Diesel 5w40.
Here's the UOA's from my 2015 Ram 1500 EcoDiesel:
So why does FCA say it is required? They want your DPF to fail?These vehicles have DPF, hence do not use API SN or other Full-SAPS oils.
How many fingers do you have on your hands?Mobil1 ESP 5w30....
xW40 DPF friendly oils are like unicorns.....you can count them on fingers of one hand...and they CANT be in VW 504/507 since that spec is only in sae30.
Castrol magnatec C3 5w40....Castrol (have to look at the service papers of previous owner...dunno its flavour)...... Repsol elite 5w40....
Common knowledge, you can imagine my reaction when I saw sticker on my Volvo D2 recommending A3/B4 Castrol.These vehicles have DPF, hence do not use API SN or other Full-SAPS oils.
AND FCA MS-12991API SN engine oil category is required.
Only 10...but you are reading post #16 here:How many fingers do you have on your hands?
. Also the Cam 2 oil listed says not for DPF filters .
DPF will not fail during warranty. FCA had big issues with bearings on that engine. ACEA A3 oils are band aid.So why does FCA say it is required? They want your DPF to fail?
