Originally Posted by Farnsworth
Originally Posted by oil_film_movies
Hydraulic pressure is felt all the way back to the oil pump. The oil filter's bypass relief threshold relieves that pressure. Fluid Mechanics 101
Sounds correct. A relief valve, dumping to atmosphere, can be put on any section of plumbing and it works only on that sections pressure. Before the oil filter is a section of plumbing working at a different pressure than after the oil filter. Seems pretty clear a bypass valve alters the pressure, determined by it's size.
Go back and read all the posts in this thread about this subject so far. He believes the filter's bypass valve somehow controls how the pump's pressure relief valve works. It simply doesn't work that way. I know you made a comment in another thread saying you thought the filter's bypass valve somehow "messed with" the pump's relief valve. Care to explain that thought? Misconceptions are pretty hard to break sometimes, but anyone reading this forum for many years should have seen how this stuff works by now.
The filter's bypass valve operates completely independent, and has absolutely no connection on how the pump's relief valve works. The filter's bypass valve simply bypasses flow around the filter media when the delta-p across the media is above the bypass valve setting, regardless of what the oil pump is doing ... simple as that.
I already know all that. You yourself said in another thread that if the filter is clogged or whatever the oil pump could go into relief. Maybe like at -20.That's what I was saying. And if there is a bypass open there, or not, it indeed does affect the oil pump relief valve's threshold.
The oil pumps relieve valve threshold is set by the oil pump designers. The oil pump will begin to return oil to the sump when this threshold is exceeded. This setting has nothing to do with the bypass valve setting in the oil filter.
