Are the DEXRON III and ATF3 same? I read the manual book says use DEXRON III for the 1996 Cherokee 4WD uses AW4 automatic tranny. I went autozone parts store and they said I can use ATF3. I am not sure if ATF3 is a DEXRON III?
Which brand ATF oil do you recommend for Jeep's AW4.
