I have a good supply of Dexron VI. Any reason not to use it for an automatic transmission drain and refill?
Under $3.50 a quart and planing on 2 or 3 drain and refills.While I do not know definitively, were it my car I'd use the DexVI without hesitation.
Was your DexVI so cheap it doesn't pay to go fetch some house brand Dex/Merc or MaxLife for the '86?
I’m not trying to argue but but do you define success?I've had better success running the correct viscosity Dex III (same as Dex II) vs. low-viscosity fluids in most older transmissions. I've found both GM and Aisin transmissions to like the "correct" viscosity better - but that doesn't mean an LV like Dex VI won't work or shorten the life.
I have run higher cSt fluids such as Mobil 1 ATF and lower cSt fluids such as full syn DEX VI.
Doesn’t matter if its January in Stowe Vermont or September in Odessa Texas.
I can’t tell any difference.
Do you understand how shear stability works in an AT and what the DEXRON-II or -III licenses specify and require as opposed to DEXRON-VI?I've had better success running the correct viscosity Dex III (same as Dex II) vs. low-viscosity fluids in most older transmissions. I've found both GM and Aisin transmissions to like the "correct" viscosity better - but that doesn't mean an LV like Dex VI won't work or shorten the life.
I do fully understand that. Thanks for being your usual obnoxious self about thins, as always.Do you understand how shear stability works in an AT and what the DEXRON-II or -III licenses specify and require as opposed to DEXRON-VI?
DEXRON-VI is the correct viscosity.
What on earth?I do fully understand that. Thanks for being your usual obnoxious self about thins, as always.
And you are 100% wrong. I should have put you on ignore LONG ago. No time like the present, though. Enjoy the holidays.
