Originally Posted By: onion
Much as I disdain Dexcool, I gotta differ somewhat. IMO, GM's plastic intake gaskets, plastic intake manifolds, and certain radiator caps WERE a bad design in and of themselves. I've seen those plastic gaskets fail even without the use of Dexcool (these failed routinely in '94 and '95 engines, which didn't come with dexcool). The plastic intake manifolds in the 3800 engines crack due to EGR heat. And those S10 radiator caps let air into the system regardless of what type of coolant is in the system.
OK, I'll back off on "nothing wrong" with the designs. I've seen plastic gasket frames work well on other manufacturers' engines, but then the EGR didn't run right through a plastic gasket, either. It still strikes me as hilarious that *any* manufacturer could get a radiator cap wrong after doing this for 100-odd years. Just how many different rad cap designs to there have to really be, anyway? That's one of those things where if I were designing the car, I'd go out of my way to use a very common, standard part. Just like every gasoline engine I used would take an L3001 (FL-1A equivalent) oil filter ;-) One of the reasons I've always liked Mopars is the fact that the little things (like rad caps) tend to be the same (or backward compatible) over a nearly 50-year span and hundreds of different models. But they didn't do the same with oil filters, unfortunately.
