Over on Xoutpost I got into a heated argument regarding using Mobil1 in my 2002 E53 BMW X5 3.0 with the GM transmission.
The factory fill was Texaco ETL8072B which from what I can read is Dex3 over on the GM site.
Now 2 years ago I was looking for an alternative to Tex ETL8072B. The BMW tech said that any Dex3 or Dex6 would work well in my tranny. I asked him if M1 was a good product he said it is one of the best for that transmission.
One of the vernerable long time posters over on Xoutpost who is generally a decent guy is telling me that I will have problems if I use the M1. He says that the makers of GM Dexron 3 and 6 has a warnign on their site which instructs users of "conterfiet" dexron atf to be ware as those "universal" fluids are not approved by GM.
Well okay I went to M1 atf site and it lists that it is compatible with Dex3. Below is M1 ATF spec sheet it lists Dexron 3.
M1 ATF Spec Sheet
To make the waters muddier I found Wolf's Head Super Synthetic ATF and it is the elixer of transmission life it covers everything including Dexron up to 6 and Texaco ETL8072B which was the factory fill and the DEX3 equivilent.
Wolf's Head Syn ATF
*Note I would use the factory fill but, they stopped making it
** Note I know the BMW says it is lifetime. Actually the service manual says CI every 100K miles
***Note I have been running the M1 since 90K, and at 142,000 miles... NO problems, shifts like new
This guy is starting to Get under my collar because he insists he is RIGHT when a good many people have made good arguments for M1.
He claims universals do not meet the specs. Am I wrong to assume M1 is okay for my transmission? he has got me concerned I might be doing something wrong that will damage the trans.
M1 ATF Spec Sheet
Wolf's Head Syn ATF
