Detailed the outside of the 500,000 mile Sequoia
Suburban Washington DC
More photos at: https://photobucket.com/u/atikovi/a/fee066f4-8493-4453-81b5-0ede775be4aa I did most of it a month ago but wiped it down and went over it again today with TW Graphine spray wax before taking pictures. Started with 2 rounds of Meguiar's Iron Decon and then used it again as a clay lube while claying with a synthetic clay mitt. Polished the paint with Meguair's 110 compound using a DA with a Meguair's medium cut foam pad. Finished with TW as mentioned. Restored headlights with 500 dry sandpaper discs followed by wet polishing with Trixact 1000 and 3000 pads. Finished with 3M coating. Tires and trim were dressed with Meguiar's Hyper Dressing at 50/50.
Not sure. Fully serviced with new timing belt and water pump, valve adjustment check, starter, plugs, filters, brake pads, calipers, rotors, brake fluid change, coolant change, springs, shocks, ball joints, axle and transfer case fluid, etc. Probably over $5000 worth of parts and service at a shop. Maybe $5-$6K? Will find out after cleaning up the inside and posting it for sale pretty soon.
Interior detailed and pics added to link in OP. First chance to use my drill brush attachment on the carpet (as seen on Mad Detailing) and really like it. These carpets we covered by mats so not very dirty, but the brush evens out the pile for a smooth clean look.
