Deposit formation of dino vs. PAO vs. POE
MS
Yea, Polyol ester kicked [censored] and took names. No great surprise there though.
CA
Do you know of any motor oils that use this ester?
USA
RedLine's use of polyol ester base stocks is their #1 selling point
I actually have a polyolester shirt. Looks great and the chicks love it.
ON, Canada eh?
Just playing the Devil's advocate here... But does your average engine need this protection? Will they ever see 275 degree heat? It is good to see the differences though... \:\!
MS
POE has other benefits besides high temp deposit control though. Like film strength and polarity.
NJ
No, but if cost was no obstacle, an optimized POE based oil would probably be superior to anything on the market. It would be pricey. I guess Redline is about as close to that as you would find.
saaber1
Pacnw
I know VW says in their patent that the intake valves reach 380 degrees C on the 2.0FSI if run for 20 minutes at 3000 rpm at full load? (found by zappergli on vwvortex). This video shows the exhaust side of a turbocharger reaches 1600F/ 900 celcius (Yowza!) (posted by someone on BITOG earlier but I can't remember who) http://www.youtube.com/watch?v=G7jVYTmql2Y&feature=related So I would guess at least the oil reaching the turbo would be that hot but I dunno about other places.
Texas
Are these formulated lubricants, or just base oils being dumped on the plate? I have seen this pic before, and the POA lube suprised me.
ON, Canada eh?
I have seen tons of engines torn a part for rebuilding/ head gaskets etc. that have run nothing but Bulk-Dino and cheap filters for many hundreds of thousands of miles and they are clean as a whistle inside most of the time, and when not, all they have are heavy varnish in them. These cars all pass emission tests and perform well so I don't see the need for this protection or added cost in today's average engines especially with today's great SM/GF-4 rated oils.
CA
The oil does not come close to touching any areas that hot. It feeds the center section which even though I've had my turbine side glowing bright orange, the center section has never glowed. It's also got the compressor on the other side to help it out. It's when the engine is shut down and the oil and air stop flowing that the heat migrates into the center section that you have problems. Not to mention many newer setups use water cooled centers.
MS
Just good enough isn't good enough for some people. When are you going to dump the Amsoil out of your car?
PA
Good question. The description says "lubricant", but I find it hard to imagine they found five lubricants that each used a different base stock exclusively.
ON, Canada eh?
I'm running this until next month when I hit the 15K KM I'm running this fill for, then I will be refilling with Amsoil as we will be almost into September by then and the cool temps at night will be here. So my short answer is Next Summer I will be running the VWB that I got on sale at Walmart.
