Oz, here is what I have (A slightly older formulation of Delvac 1, 5W40; I assume the numbers are somehwat better now since they have had time to tweak it since this test was done):
CAT 1M-PC
Ring Side Clearance - Loss mm - 0.012
Piston, ring, and liner scuffing - 0
Piston Ring sticking - 0
CRC-L-38 (3X, 120 hr)
Bearing Wt. Loss, mg - 20 mg
Extended 128 hr. Seq. IIIE
Cam and Lifter Wear - um, 5.2
In Gas Engine, 50,000 miles accumulated, 25,000 mile Oil Drain Interval, 2.0L, I4;
Oil Cons. averaged 6,000 miles/qt
Oil Vis.
[email protected] C - 15%
Used Oil TB - 8.4
Emissions in Gas Engine for above:
HC - 0.2
CO - 1.85
NOx - 0.60
