I am asking this question to gain insight and not as an attempt to doubt or argue...what is it in the DELVAC-1 literature that leads you to think it might not contain proper FMs?
Thanks
Thanks for the clarification and I think I understand your concerns.
The Delvac-1 application is for HD automatic transmissions:
Mobil Delvac 1 ATF is a fully synthetic fluid recommended by Allison Transmission, Inc. approved against the Allison TES-295 Specification. The fluid is designed to meet the demanding requirements of modern heavy duty automatic transmissions. The synthetic base oil composition enables excellent performance even in some of the harshest of operating conditions. It offers outstanding gear shifting and power transfer performance.
The friction modification chemistry in ATF's is for wet clutches and is different than for MTF's. MTF's for Light Truck and passenger vehicles usually contain high dosages of a special calcium and or magnesium chemistry to insure the proper COF for engagement and disengagement of the synchronizer. While Delvac-1 would be safe for copper-alloy (phosphor-bronze) synchronizer assemblies, it does not contain the proper FM for MT's.
ZF6TechInfo said:
TRANSMISSION OIL (status) - Vascular flow of oil through the porous Phosphorus-bronze (Pb) material of each synchronizer is essential for effective British Thermal Unit (BTU) heat exchange occurrence. Frequent transmission oil changes will ensure lower Pb particle levels suspended in the oil. The ZF S6-40 6-speed transmission is lubricated by engine type oil. Manufacturer recommendations specify the use of GM P/N 1052931 (5w-30) or BMW P/N 07510009420 (10w-60) oil.
Approximate oil capacity of the ZF S6-40 is 2.2 quarts....
The information here is somewhat contradictory. The GM P/N 1052931 was originally a 7.7 cSt@100C ATF fluid with a 'bumped-up' phosphorus level, whereas a 5w-30 viscosity MTF ranges between 9 and 10.5 cSt with the special calcium and or magnesium chemistry.
This group of MTL’s are in the 9.X to 10.5 cSt range (SAE 75W80):
1. Redline MTL 75W80 (10.4 cSt according to
https://www.redlineoil.com/Content/files/tech/MTL_GO_PROD_INFO_2020.pdf
2. Amsoil MTF (10.1 cSt according to (
https://amsoilcontent.com/ams/lit/databulletins/g2080.pdf )
3. GM Synchromesh’s (approx. 10.5 cSt)
4. Volvo MTF 645
5. Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic MTF
6. Lodexol (Morris Lubricants) MTF
7. Motylgear 75W-80
The BMW recommendation for an equivalent 75W90 MTF is possibly for a higher horsepower/higher torque engine in front of the MT.
