http://www.eaa49.av.org/techart/str_oil.htm
Last March, a pair of Mercedes-Benz Engineers (Rudolf Thom and Karl Kollman)along with pair of Shell Oil engineers (Wolfgang Warnecke and Mike Frend)wrote an SAE technical paper (No. 951035) on "Extended Oil Drain Intervals: Conservation of Resources, or Reduction of Engine Life?" Among the many interesting results presented in the paper was a graph showing cylinder-wall wear-rate Measurements correlated with cylinder wall temperature. Cylinder wear rates(in micrograms per hour) were monitored as a function of cylinder-wall temperature in a test engine specifically fitted with radionuclide-impregnated cylinder liners. Three test were done so that three different kinds of oils could be used. In one test sequence, a straight 30 weight oil was used; in another, 10W-30 multigrade; and in the third, straight 10 weight oil. (The test engine was a Mercedes-Benz OM 616 2.4-liter, 4cylinder diesel.) In each case, the engine was operated at fixed speed, torque and temperature conditions until constant wear rates were observed. Wear rates were then plotted against cylinder wall temperature.
The graph of cylinder-wall wear rate versus cylinder wall temperature tends to be bathtub-shaped, with wear increasing sharply at each temperature extreme (as you'd expect). But while two of the oils turned in very similar wear performance, one oil stood out as protecting the engine against wear at the extremes of temperature. That oil was plain SAE 30 (Straight-grade 30-weight). At either extreme of temperature, the maximum wear rate with 10W-30 was more than double that of the straight SAE30 oil. (The worst performance was turned in by straight 10-weight.)
