dello 10w30 vs. chevron supreme 10w30
western pa
has anyone ever compared these two? have they ever run head to head? are there any advatages of using either?-your thoughts please.
I use nothing but Delo400 10w-30 in my diesel application on a golf course vehicles(all deisel engines). I'd slip in some Chevron 10w-30 in diesel cushman but conditions are different from Mowers that see alot of dust and grass clippings. I did ok but the Delo seems like a better stable oil in extreme conditions but conditions are different with gasoline engines. I'd slip in the Chevron in cushmans and see no difference from manual oil OCI from Delo400 but perfer the Delo400 in extreme dusty conditions.
does the delo 10-30 have moly? does it have a additive package that would work well in a higher mileage pickup ?
Delo400 has no Moly but in certain driving conditions Moly is not necessary as Penzoil has change it's formulation with no Moly. There tend to be more combution by products in higher mileage engines and see a good reason to extend your engine's longivity with using Delo400 as I've used it other high mileage vehicles as a cushions. What's a few cents more for added protection.
Delo 400 has a more rubust additive package and higher TBN and would be better for extended drains in a gas vehicle. Gene
The Delo will need to be around a 12 cSt to be rated. The Rotella 10w-30 I use is that visc, and I believe the standard is based on HT/HS. Chevron Supreme is what, about 10 cSt?
quote:
Originally posted by Audi Junkie: The Delo will need to be around a 12 cSt to be rated. The Rotella 10w-30 I use is that visc, and I believe the standard is based on HT/HS. Chevron Supreme is what, about 10 cSt?
Delo 400 10w-30 is 11.1 cSt... Wayne
I read this on the Chevron site and can't remember reading this before about the new Delo.Delo 400 continues to use ISOSYNTM technology, which provides equal or better extended drain capability and fuel economy as synthetic oils, but at a much lower cost. Although Gene posted Delo as a extended drain oil back then now the company came out and posted it. [Smile]
