People often use the word SHEAR to mean a decrease in viscosity of a motor oil. We all know that mineral based motor oils initially thin a little with use. This is in part from the dilution with gasoline and also the consumption of viscosity index improvers. It is less of a problem today than in the past but still occurs.
However, the definition of SHEAR is not a permanent thinning that occurs with use but a temporary, functional thinning that occurs in the actual bearing. It is an instantaneous thinning. When the oil leaves the fast moving, hot bearing the oil reverts back to it normal viscosity.
Often we hear of oils “shearing” to a lesser grade. This is as if a 30 wt. oil becomes a 20 wt oil. This is not the case. It is an inappropriate use of the term. An oil SHEARS to a thinner oil because it has less viscosity than the temperature alone would account for. At 150 C an oil may have a viscosity of 4. But under high RPM, pressure and temperature it is found to have a viscosity of 3. After that oil comes out of that higher load/RPM/pressure situation it becomes the same oil as before entering that bearing condition. It goes back to it’s regular viscosity of 4.
This is my understanding of the use of the word SHEAR in automotive motor oil applications.
aehaas
