Team,
First oil analysis I post here in more than 13 years.
- 2018 Silverado 1500, Crew Cab, Z71 with the 5.3L (L83) engine
- No idea what oil the dealer used, but should be 0W-20/Dexos 1 as recommended
- 5200 miles on the oil...21,520 overall
- First 3K miles was mostly long trips visiting family and moving out of state. The second half is completely different...short trips (commute is 3 miles round trip), 160* thermostat (yikes), and extremely dusty environment
- AC Delco oil filter
- K&N "cold air induction"...primary reason for analysis
Code
RICARDO: We found some fuel in this 0W/20 oil, but just a minor amount. 1.0% fuel is small enough to be from normal use (e.g. short trips) or taking the sample before the engine is fully warm. With the viscosity being well inside the 0W/20 range and wear looking good, you can be confident fuel hasn't caused issues. Averages on the far right show typical 5.3L EcoTec3 wear after a ~6,700-mile run. Aluminum through copper are the wear metals and they're actually a little better than we'd expect after a 5,200-mile run. No issues stand out for this young Silverado. Aluminum - 1 Chromium - 1 Iron - 10 Copper - 24 Lead - 0 Tin - 0 Molybdenum - 137 Nickel - 0 Manganese - 4 Silver - 0 Titanium - 0 Potassium - 1 Boron - 28 Silicon - 17 (Happy with this. The K&N filter seems to be doing a decent job.) Sodium - 4 Calcium - 1234 Magnesium - 457 Phosphorous - 687 Zinc - 771 Barium - 1 Viscosity @210*F - 48.4 @100*C - 6.79 Flashpoint - [b]365[/b] Fuel - 1.0 (Strong smell of fuel while changing oil. I thought I had some dilution, but I was obviously mistaken) Water - 0% Antifreeze - 0% Insolubles - 0.2 TBN - Not done
