Originally Posted By: HerrStig
The "boil off" works in conjunction with a positive voltage on the plate which attracts the electrons, which must pass the "grid". The "grid" causes the electron stream to follow the amplitude of the input signal applied to it. If you look at high power TV transmitters you will find big power triodes and tetrodes still in use. A lightning shot on a transmitting antenna is much less likely to blow up a big tube, many of which are water cooled.
I know that solid state transmitters have generally replaced Traveling Wave Tubes (very fancy vacuum tubes) in military phased array radars, but think that TWTs are still common in civilian applications like weather radars and probably in simpler military systems. No need to generate multiple pencil beams at multiple frequencies when the clouds are not supersonic and trying to kill you... ;^)
