While we moved to DE, 30 year old daughter (stayed in NY) with her first car she owns herself (was her Mom's) goes to a chain tire store in NY that starts with an M to get NYS inspection and rims with snows swapped on. Should be about $50 total. $20 & $30.
They said her rear brakes were rusty and she needed calipers, pads and rotors for $987. Your car is kind of held hostage since they won't pass inspection as is. I did the rear brakes myself and I know the critical areas were cleaned and lubed properly. And I used Akebono pads and coated rotors. After some discussion they came to $700 for pads and rotors and tire swap and inspection. I would have said to swap the tires and fail the inspection and gotten an indy mechanic to look it over. But she is stressed and wanted safe brakes so she went ahead and got the pads & rotors installed.
So either she needed calipers or she didn't. If she did then they should have been replaced. If she didn't then they should not have been listed as needed parts. You don't negotiate the price down by eliminating calipers if they were really needed.
And I am sure they did not use Akebono pads or probably not coated rotors.
So another young female taken advantage of by a tire chain. They charged her about $500 labor for an hours worth of work? And did they even clean and lube the critical areas like I would have done. You won't know for several months.
I told her a $$ lesson to find a trusted indy mechanic.
