I have a 75 CJ5 with a Dana 44 rearend with a powerlock carrier. I just finished replacing the axle bearings & seals. What would be the best gear grease to use in it?
Some of the aftermarket diff makers spec a different oil than what the OEM called for.I have a 75 CJ5 with a Dana 44 rearend with a powerlock carrier. I just finished replacing the axle bearings & seals. What would be the best gear grease to use in it?
