ISO Code 24/23/16
UOA: https://bobistheoilguy.com/forums/t...9-miles-2019-vw-jetta-1-4t-tan-tbn-pc.337794/
Question: In the 5th image down from the top. Is it my imagination or does it appear that there is a slight deformity in the gasket specifically between the 9 o’clock and 11 o’clock position?
I've seen other filters with a wavy looking base gasket after they have been used and removed.Quite a robust filter, there.
You have? Where is the proof of that?I've seen other filters with a wavy looking base gasket after they have been used and removed.
Not directed at you btw. Just making a point.
These really are nicely built filters. Thanks, OP.
Robert: looks very good. Did another of these filters go back on?
thank you
