Needed some decent floormats for the Civic with winter coming up. I like the custom fit all season rubber mats, but $100+ per set is more than I wanted to spend. GF bought some cheap clear plastic generic floormats when she got the car, but they slid around and didn't protect much. So here's what I did:
Went to the local big box hardware store. Bought two cheap 26" x 5' indoor/outdoor rugs. Car interior carpet is gray, so I bought gray rugs. Rugs are the real heavy duty type of weave, almost like a plastic fiber. Backing is the rubber type of material. No edging/border, just the top fiber and backing.
Came home, pulled the OEM floormats out as templates. Using a sharpie I carefully traced the floormat onto the backing of the rug. Then used a box cutter to cut out the tracings. After cutting them out I used a scissors to trim up any loose fibers around the edges.
Put em' in the car, and they look awesome. Fits perfectly, covers the OEM floormats 100%, doesn't look gaudy at all. The rugs have enough weave to soak up any and all snowy, salty winter slop that comes along. Non skid backing means they don't slide around. Unlike generic fit mats, it actually covers 100% of the floor. Can be hosed off or thrown away when they get grungy.
Total parts cost - $13.10 ($6.55 each) Two rugs were enough to do front and back mats
Labor - about 15 minutes worth of work
Tools required - box cutter, marker, and scissors
Hey, looks good and beats spending $100+ for the really nice rubber all-season mats.
Next project: make a trunk carpet covering out of similar material.
